Re: 300U LPG
Posted by Morgan on February 03, 2002 at 22:06:34 from (63.14.159.172):
In Reply to: 300U LPG posted by jett on February 03, 2002 at 15:38:19:
jett LP is not that hard. 1 undo the high press hose at the reg. (smell round thing with h p hose in&out) open valve at tank (crack/ close). This will tell if hose is pluged. Do same with hose between reg an converter. Reg opens by vacum ck that at carb if reg dose not open you will not get fuel. Converter changes LP from liquid to vaper. Converter has water hoses to and from. There should be a small button on reg push and this will open reg as a manual ck. IF eng.dose not have vacum it will not open carb. You can get overhaul kits for reg converter and carb from most LP dealers. Ther will be mafg and model on each part. Hope this is of some help, if not e- mail me and we will try again. Morgan
Post A Followup
: Re: Re: 300U LPG
Today's Featured Article - Product Review: Kreem Brand Fuel Tank Liner - by Staff. This condition has occurred on a few machines that we have had and fortunately we were able to borrow the technique used at the local motorcycle shop. The product that we have used is called Kreem thouh there are others on the market, this one was recommended and available. This particular product is sold in three parts, a bottle of etch, dryer, and sealer. We were fortunate enough to start the process with stern warnings from those that had used this type of product before. The horror ... [Read Article]
