Re: Is it time for a Carb rebuild ????
Posted by Michael Soldan on February 04, 2002 at 14:24:26 from (216.46.130.48):
In Reply to: Is it time for a Carb rebuild ???? posted by Jerry on February 04, 2002 at 08:10:15:
Jerry, it sounds like an icing carburetor, which will foul plugs and put gasoline into the oil.When the tractor is running does there appear to be snow on the carb body? Place your hand on the carb and the bottom of the manifold it flows into, if it feels cold when the tractor has been running for several minutes you have an icing problem. I once had an old Allis that did this, I ran a flex hose from the outside air intake up under the hood where it sucked in warmed air and it helped greatly. I made a vest for the tractor as well to house the heat from the engine and solved the winter plug fouling problem..not to say you don't have a carb problem , but this is something you could try, also a can of deicer in the fuel tank will remove the moisture in the fuel system. I've seen snowmobile carbs ice up to the point where the machine won't run...let it sit a few minutes and the engine heat melts the ice in the carb and away you go...I use deicer in tractor, truck and sled in the winter, especially the tractors which may sit several weeks before use. Good luck from Mike in Exeter Ontario
Home
| Forums
Today's Featured Article -
Trenching With a Plow - by Staff. Introduction: This interesting information came from one of the discussion forums here at YT. We thought we should place it up front so it could be read by anyone interested in putting old iron to work. [Editor] I tried something new today, and it worked so well I thought I should post it - in case it might help someone else. I'm running 100 yards of 4" drain pipe from the gutter downspouts of our house to a pond down the hill. This should hel
... [Read Article]
Latest Ad:
[More Ads]
Copyright © 1997-2025 Yesterday's Tractor Co. All Rights Reserved. Reproduction of any part of this website, including design and content, without written permission is strictly prohibited. Trade Marks and Trade Names contained and used in this Website are those of others, and are used in this Website in a descriptive sense to refer to the products of others. Use of this Web site constitutes acceptance of our User Agreement and Privacy Policy TRADEMARK DISCLAIMER: Tradenames and Trademarks referred to within Yesterday's Tractor Co. products and within the Yesterday's Tractor Co. websites are the property of their respective trademark holders. None of these trademark holders are affiliated with Yesterday's Tractor Co., our products, or our website nor are we sponsored by them. John Deere and its logos are the registered trademarks of the John Deere Corporation. Agco, Agco Allis, White, Massey Ferguson and their logos are the registered trademarks of AGCO Corporation. Case, Case-IH, Farmall, International Harvester, New Holland and their logos are registered trademarks of CNH Global N.V. Yesterday's Tractors - Antique Tractor HeadquartersWebsite Accessibility Policy |
