Re: What Kind of Plug For M Radiator
Posted by Bob M on February 05, 2002 at 09:46:40 from (165.170.128.65):
In Reply to: What Kind of Plug For M Radiator posted by John on February 05, 2002 at 09:22:59:
Radiator drain is a standard 3/8" NPT. Suggest however instead of installing a plug, use a short 3/8" pipe nipple and cap. Length of the nipple should be so the lower end threads just show beneath the bolster casting. This arrangement makes draining the radiator easier and much less messy...
Post A Followup
: Re: Re: What Kind of Plug For M Radiator
