Farmall Tractors Discussion Board
Re: Overhaul Break-in Procedure (or, another ^$#~ H post)
Posted by bermuda ken on July 28, 1999 at 10:34:22 from (205.173.178.114):
In Reply to: Overhaul Break-in Procedure (or, another ^$#~ H post) posted by Bill(Tx) on July 28, 1999 at 08:23:22:
I agree with Red. Avoid idling if at all possible, and recheck the head bolt torque and rocker arm gaps after 5 hours. Change oil frequently and avoid heavy loads for the first 5 hours. After that, run it the way you plan for the rest of its life. Plowing or some heavy loading will definately keep the rings seated. Check for leaks and have fun.
After this is all done, its time to get another IH tractor and start the project cycle all over........
Post a Followup
: Re: Re: Overhaul Break-in Procedure (or, another ^$#~ H post)
