Re: Re: Re: Un-Super H
Posted by Denny Frisk on February 05, 2002 at 15:14:31 from (12.4.181.2):
In Reply to: Re: Re: Un-Super H posted by Pete on February 05, 2002 at 14:55:08:
Pete - Sounds like You have a stage #I SH that had the M&W Live Hyd. kit put on it. I bet the tractor still has the belly pump right? And in order to get room on the short Super H engine the Delco Distributor had to be put on as well, otherwise the distributor cap would be in the same spot as the oil filter. The later Stage #II Super H's had the box-shape hyd. res. under the tank taking up most of the avail room so the battery ended up under the seat. I think the Serial # break was 19226 = last Stage @I, #19227 the first Stage #II. The break was in Oct. '53 think.
Post A Followup
: Re: Re: Re: Re: Un-Super H
