Re: Re: Clicking sound out of 2nd. gear Farmall Cub
Posted by Ben on February 05, 2002 at 17:40:43 from (152.163.204.61):
In Reply to: Re: Clicking sound out of 2nd. gear Farmall Cub posted by Bermuda Ken on February 05, 2002 at 14:58:59:
I had a 48 cub with same problem clicking and noisy in 2nd. I replaced the small idler gear and reversed the large . second gear Those two run together in 2nd The larger gear is straight toothed I took a grinder and beveled the front edge of each tooth so it would engage better and now it's perfect. I got the small gear out of a TSC parts book I think it to be about 80.00 but am not sure as I did this a few year back. It worked!! Hope this helps Ben I think the name for the small gear to be call reverse Idler.
Post A Followup
: Re: Re: Re: Clicking sound out of 2nd. gear Farmall Cub
Today's Featured Article - Pitfalls of Tractor Engine Rebuilds - by Chris Pratt. The first pop after you have put the machine together with your own hands is exciting and pleasing. The whole experience can be marred if one moves too fast and makes too many assumptions that they can just use "as is" some parts they should be closely scrutinizing and possibly attended to. In such cases, rework makes what could have been a fun project turn into an irritant or even a nightmare. Minor Irritants To give you an example of an minor but irritating proble ... [Read Article]
