Re: Re: battery connections on a farmall bn
Posted by steve on February 06, 2002 at 16:20:58 from (204.246.222.106):
In Reply to: Re: battery connections on a farmall bn posted by ScottyNY on February 06, 2002 at 15:29:02:
starter and lights dont care. the only important thing is charging the battery. if it was negative ground, i would asssume tht is right for now. start it up and look at the amp meter. also check battery voltage while running. if you ae getting 13.5 (for 12 volt) or 7 (for 6 volt) you are o.k. Like he siad, if you have an alternator then you know it is negative ground. generator could be either + or -.
Post A Followup
: Re: Re: Re: battery connections on a farmall bn
Today's Featured Article - Identifying Tractor Noises - by Curtis Von Fange. Listening To Your Tractor : Part 3 - In this series we are continuing to learn the fine art of listening to our tractor in hopes of keeping it running longer. One particularly important facet is to hear and identify the particular noises that our ... [Read Article]
Latest Ad: 1997 cub cadet 7275 compact utility tractor 4wd hydro trans cracked block 3500 [More Ads]
