Re: Re: Farmall/John Deere discussion
Posted by George From Ontario on February 07, 2002 at 06:32:12 from (216.183.142.212):
In Reply to: Re: Farmall/John Deere discussion posted by donwisc on February 06, 2002 at 10:40:06:
I have used both . My Dad had a 300 Utility and traded it on a Leyland 344 . We later bot a 35 MF Diesel at an auction . The Quick hitch was definately better . It was easier to hitch . Down Pressure ment that you could lift the rear of the
Tractor with a block of wood under the drawbar then shove rails under the wheels and drive out of a mud hole if you got stuck . It is very sad that
IH did not share the technology as Quick Hitch should have been the industry standard .
Just My opinion !
George
Post A Followup
: Re: Re: Re: Farmall/John Deere discussion
