Re: 1st tractor
Posted by Haas on February 07, 2002 at 14:03:56 from (129.37.117.217):
In Reply to: 1st tractor posted by Robert C. on February 07, 2002 at 06:32:18:
The first tractor I ever operated was a Super A. I was 11 or 12 years old and my first job was driving to pull the rope to lift loose hay into the barn with a hay fork. Second job was driving the wagon to pick up hay bales in the field. I was too small to load bales. That was when my Dad was converting from loose hay to bales. The first tractor that I owned myself was ... a Super A. Bought it in pieces about 25 years later(not the same one though) and restored it and used it with a Woods belly mower to mow my 5 acres.
Post A Followup
: Re: Re: 1st tractor
Today's Featured Article - Tuning-Up Your Tractor: Plugs & Compression Testing - by Curtis Von Fange. The engine seems to run rough. In the exhaust you can hear an occasion 'poofing' sound like somethings not firing on all cylinders. Under loaded conditions the tractor seems to lack power and it belches black smoke out of the exhaust. For some reason it just doesn't want to start up without cranking and cranking the starter. All these conditions can be signals that your unit is in need of a tune up. Ok, so what is involved in a tune up? You say, swap plugs and file the points....now tha ... [Read Article]
