Re: Re: Re: Re: Re: Re: 706 slipping
Posted by John M on February 08, 2002 at 15:48:05 from (64.6.2.230):
In Reply to: Re: Re: Re: Re: Re: 706 slipping posted by bryan on February 07, 2002 at 20:20:15:
Oil/Lube light should come on when cl pedal is depressed & go out just before tractor begins to move when in low gear & at higher eng RPM. It is adjusted at Dump Valve linkage at MC Valve.(long 1/4" bolt, shorten or lenghten to get proper results) On a 706, the oil light doubles as eng oil\trans lube press warning, & should never come on while eng is running or cl pedal is not depressed.
Post A Followup
: Re: Re: Re: Re: Re: Re: Re: 706 slipping
Today's Featured Article - Hydraulics - Cylinder Anatomy - by Curtis von Fange. Let’s make one more addition to our series on hydraulics. I’ve noticed a few questions in the comment section that could pertain to hydraulic cylinders so I thought we could take a short look at this real workhorse of the circuit. Cylinders are the reason for the hydraulic circuit. They take the fluid power delivered from the pump and magically change it into mechanical power. There are many types of cylinders that one might run across on a farm scenario. Each one could take a chapter in ... [Read Article]
