Farmall Tractors Discussion Board
LP 706 L Won't Run
Posted by Richard Henninger on July 28, 1999 at 19:40:00 from (216.192.207.1):
Started the tractor Saturday and drove to field. Went about 30 feet pulling a turning plow and bogged it down. Backed up and started off again and bogged down again. Restarted the engine and it would not rev up . Would sart and idle but if you opened the throttle it would die. Limped back to the shed and llet the engine idle while the plow was unhooked and a blade attached. Parked the tractor and tried the throttle before turning it off. It reved up so I tried to do some work, it ran okay for a while but die three times and backfired as it died. It cranked up the first two times it died, but the third time it died it wouldn't restart and still won't start.
I have replace the condenser, points, rotor button and distributor cap. Lp is getting to the regulator.
What is the correct gap on the points? They are set at .018. Any ideas?
Thanks,
Richard
Post a Followup
: Re: LP 706 L Won't Run
