Re: Noise in Cub transmission housing
Posted by David Jr. on February 09, 2002 at 11:21:19 from (216.34.188.131):
In Reply to: Noise in Cub transmission housing posted by David Jr. on February 08, 2002 at 09:39:30:
The throwout bearing is old, but it works fine. It is quiet when I press the clutch pedal and the shaft stops spinning.
I'll have to check for that oil hole for the bearing. The noise doesn't change when PTO is engaged.
However, there is now some red transmission oil leaking out of the transmission shaft case which may be from the transmission bearing, so it must be getting oil. Perhaps the bearing is shot? I overfilled the case a little after hearing the noise to make sure that oil got to that bearing.
Post A Followup
: Re: Re: Noise in Cub transmission housing
