Re: Cub engine block leak - Help!
Posted by Farmall-Nut on February 09, 2002 at 15:59:01 from (216.24.65.159):
In Reply to: Cub engine block leak - Help! posted by David Jr. on February 09, 2002 at 14:26:20:
David,dropping the pan will probably show you nothing.The heat from your engine causes the crack to open,therefore acool block normally wont leak.I dont recommend using the "stop leaks" but if you do as I have out of need I suggest the aluminum particle form.I dont remember the name but NAPA & Advance carry it.The only thing Barrs Leak ever did for me was plug the radiator cores.Hope this helps.
Post A Followup
: Re: Re: Cub engine block leak - Help!
Today's Featured Article - Pitfalls of Tractor Engine Rebuilds - by Chris Pratt. The first pop after you have put the machine together with your own hands is exciting and pleasing. The whole experience can be marred if one moves too fast and makes too many assumptions that they can just use "as is" some parts they should be closely scrutinizing and possibly attended to. In such cases, rework makes what could have been a fun project turn into an irritant or even a nightmare. Minor Irritants To give you an example of an minor but irritating proble ... [Read Article]
