Re: Has anyone ever used high-temp loctite on 560D sleeves?
Posted by Old-Dutch on February 09, 2002 at 17:05:27 from (216.165.154.181):
In Reply to: Has anyone ever used high-temp loctite on 560D sleeves? posted by Matthew on February 09, 2002 at 12:47:08:
Very good Matthew. Make sure and clean up the out side of sleeve well and also the bore. When you are ready to install, use Loctite green, it is called sleeve and valve seat retainer. Used it for many years and never had it fail. Just make sure it is clean when installing and don't work to slow because when it starts to set you will not move it. Good luck.
Post A Followup
: Re: Re: Has anyone ever used high-temp loctite on 560D sleeves?
