Re: International 350U
Posted by Mark W. on February 09, 2002 at 17:24:14 from (63.168.30.16):
In Reply to: International 350U posted by Glenn M. on February 09, 2002 at 05:53:16:
It would be prudent to be conservative and assume the torque amplifier (if it has one) is out, unless you can get the engine to run well enough to prove otherwise. (The tractor will run and work without it, but it's an EXPENSIVE repair if you want the tractor to be "just right.") Also, check the steering for excessive play. The torque amplifiers and the steering boxes were the Achilles' heels on these tractors.
Mark W.
Post A Followup
: Re: Re: International 350U
