Farmall Tractors Discussion Board
Re: Could an H handle a round bale?
Posted by Larry T on July 28, 1999 at 21:12:10 from (206.228.213.41):
In Reply to: Could an H handle a round bale? posted by Ryan on July 26, 1999 at 19:13:46:
Neighbor bought a commercial 3 point hitch for his H. Got it all mounted and backed into a 4X5 round bale of fescue and the best his would do was to get the bale on the fork and most of the weight on the tractor. The bale could not be lifted to clear the ground but he was able to drag the load. The front of the tractor remained stable. If his lift arms were shorter and the bale spear was closer to the rear axle I believe he could have handled the bale. This bale did not weigh anywhere near 1500 lbs. however. More like 1000 lbs. max.
Post a Followup
: Re: Re: Could an H handle a round bale?
