Re: Hydraulic help
Posted by cd on February 10, 2002 at 20:05:40 from (4.17.80.147):
In Reply to: Hydraulic help posted by K.B. on February 07, 2002 at 19:42:53:
i have a 240 also, it's most likely your safety pressure release valve, it was sticking and building tremendous pressure, hence the heat on the pump, now it wont work, because the relief in the valve is sticking open, heres the fix: locate the valve and remove it (it should be on the inner right side next to the hydra touch spool), then take off the end cap with 4 bolts, it is under pressure, pull the guts out and lay on a towel, this is simple but sound hard, now take a piece of emory cloth or a heavy duty scotch brite and clean the cylinder wall of burrs and scuffs, replace the o-ring on the piston with a new one, polish up the piston as well removing ALL burrs, then clean the entire unit in diesel or similar until you are sure that no dirt is present (very small pieces can make it stick), then reasemble the unit and replace it on the tractor, let the oil fill hole open, cycle your 2 point and add fluid as nessecary then replace the cap, it all of this doesnt work, try again and again because this is it unless you blew the seal out of your hydraulic pump, just check your engine oil to see if there is ALOT of extra oil, if there is then the seal is bad, it is easy to fix just remove the pump then the gear and so on. hope this all works because it is a rough system to work on but thats what is wrong with it because it have been through it.
Home
| Forums
Today's Featured Article -
Pitfalls of Tractor Engine Rebuilds - by Chris Pratt. The first pop after you have put the machine together with your own hands is exciting and pleasing. The whole experience can be marred if one moves too fast and makes too many assumptions that they can just use "as is" some parts they should be closely scrutinizing and possibly attended to. In such cases, rework makes what could have been a fun project turn into an irritant or even a nightmare. Minor Irritants To give you an example of an minor but irritating proble
... [Read Article]
Latest Ad:
[More Ads]
Copyright © 1997-2024 Yesterday's Tractor Co. All Rights Reserved. Reproduction of any part of this website, including design and content, without written permission is strictly prohibited. Trade Marks and Trade Names contained and used in this Website are those of others, and are used in this Website in a descriptive sense to refer to the products of others. Use of this Web site constitutes acceptance of our User Agreement and Privacy Policy TRADEMARK DISCLAIMER: Tradenames and Trademarks referred to within Yesterday's Tractor Co. products and within the Yesterday's Tractor Co. websites are the property of their respective trademark holders. None of these trademark holders are affiliated with Yesterday's Tractor Co., our products, or our website nor are we sponsored by them. John Deere and its logos are the registered trademarks of the John Deere Corporation. Agco, Agco Allis, White, Massey Ferguson and their logos are the registered trademarks of AGCO Corporation. Case, Case-IH, Farmall, International Harvester, New Holland and their logos are registered trademarks of CNH Global N.V. Yesterday's Tractors - Antique Tractor HeadquartersWebsite Accessibility Policy |
