Re: No Spark
Posted by The Red on February 11, 2002 at 06:52:47 from (206.246.187.2):
In Reply to: No Spark posted by Dick from N.H. on February 11, 2002 at 06:40:11:
Dick the mag settup is not connected to the voltage system. When you kill the mag, you are actually grounding it to the frame. Sounds like a faulty switch or the wire is grounding somewhere from the mag to the switch. Was it working before you converted to 12 volt?
Post A Followup
: Re: Re: No Spark
