Farmall A rad can you swap?
Posted by chad from michigan on March 25, 2009 at 17:58:41 from (67.142.164.24):
I have a 1945 A with a bad rad. I have a 1940 A parts tractor with a good Rad. The new one uses spring loaded latches for the hood where the old one uses screws. Can I use the older one in my new model. I have the older one on it but have run it for 1 year with out the hood and grill thinking it would not work. am I off my rocker or will it bolt back up or can I make any modifications to make it work?
Thanks
