Re: Do we like yellow IHs???
Posted by Glenn(WV) on February 12, 2002 at 15:22:13 from (67.201.149.90):
In Reply to: Do we like yellow IHs??? posted by The Big V on February 11, 2002 at 17:48:17:
I would also expect that by the time a company is done with an industrial tractor, it's pretty well worn out. I used to work at a power plant. The plant would buy new equipment and run it to death with little or no maintenance. We had a diesel forklift; the engine's rings were worn so bad that it barely had enough compression to start, and it burned more engine oil than diesel fuel. The plant FINALLY bought a new one when the old one completely died.
If you find a used industrial tractor, I wish you the best of luck with it.
Post A Followup
: Re: Re: Do we like yellow IHs???
