460 pinion end play ?
Posted by T. Gatzemeyer on February 12, 2002 at 15:50:20 from (12.64.217.139):
Installing a different ring and pinion in a Farmall 460 that I'am restoring and I'am having problems getting the thing set. The main thing is the pinion is moving front to back about .030. Is this normal? IT manual says nothing about end play or how to adjust it. Bearing look good and moves about as much as the old one. There doesn't seem to be anyway to adjust it with shims to get the play out of the bearing. If this is normal do you adjust the backlash with the pinion pushed back or pulled forward? Thanks for any help.
Post A Followup
: Re: 460 pinion end play ?
Today's Featured Article - Hydraulics - Cylinder Anatomy - by Curtis von Fange. Let’s make one more addition to our series on hydraulics. I’ve noticed a few questions in the comment section that could pertain to hydraulic cylinders so I thought we could take a short look at this real workhorse of the circuit. Cylinders are the reason for the hydraulic circuit. They take the fluid power delivered from the pump and magically change it into mechanical power. There are many types of cylinders that one might run across on a farm scenario. Each one could take a chapter in ... [Read Article]
