Re: F-12 Radiator hoses
Posted by JDM on February 12, 2002 at 17:59:08 from (206.74.34.93):
In Reply to: F-12 Radiator hoses posted by Stevie on February 12, 2002 at 16:56:06:
Measure the OD of the outlets and measure the length osfspace in between the two holes and add 1 1/2 inch.I think they are 2 1/2 ID inch and both of mine were 4 or 5 inches long.
Post A Followup
: Re: Re: F-12 Radiator hoses
Today's Featured Article - Tuning-Up Your Tractor: Plugs & Compression Testing - by Curtis Von Fange. The engine seems to run rough. In the exhaust you can hear an occasion 'poofing' sound like somethings not firing on all cylinders. Under loaded conditions the tractor seems to lack power and it belches black smoke out of the exhaust. For some reason it just doesn't want to start up without cranking and cranking the starter. All these conditions can be signals that your unit is in need of a tune up. Ok, so what is involved in a tune up? You say, swap plugs and file the points....now tha ... [Read Article]
