Re: Farmall C Leaking Gear Oil
Posted by ScottyNY on February 13, 2002 at 16:18:07 from (128.59.6.107):
In Reply to: Farmall C Leaking Gear Oil posted by Pat Stephens on February 13, 2002 at 09:41:38:
I'm with Pat. The old seal may have worn just enough of a low spot in the pinion over the years to cause your leak. If you drive two of the new style seals in there with them landing in a slightly different spot, it'll probably dry up for you. Good luck! Scotty
Post A Followup
: Re: Re: Farmall C Leaking Gear Oil
