Re: Hydraulic Problems
Posted by John M on February 13, 2002 at 17:28:14 from (64.6.1.223):
In Reply to: Hydraulic Problems posted by Jim on February 13, 2002 at 15:49:29:
Their is a red warning lamp below RH guage cluster for lube oil press. If lamp is working, it will come on only when clutch pedal is depressed or eng off/key on. Any other time will indicate a bad steering\TA pump or a leak in steering or TA circut. Your steering/brake problem could also be a bad relief valve capsule at the MC Valve. Press. at lube press sending unit should be 18-22#
Post A Followup
: Re: Re: Hydraulic Problems
