Re: Hydraulic Problems
Posted by the tractor vet on February 13, 2002 at 18:17:11 from (216.196.13.132):
In Reply to: Hydraulic Problems posted by Jim on February 13, 2002 at 15:49:29:
You more then likely have a stuck regulator valve in the MCV yours is the fourth one this year. And it probable would not hurt to put in a new spring kit in the MCV and set the prussure at between 245 and 265 LBS . If it picked up prime after the filter change then i do not think your pump is bad. The job is not hard to do . Just becareful when removing the caps over the valves they are under spring prussure and thinks will fly.
Post A Followup
: Re: Re: Hydraulic Problems
