Re: Generator-Bob M Help ?
Posted by gene b on February 13, 2002 at 19:44:35 from (63.42.174.138):
In Reply to: Generator-Bob M Help ? posted by scotty on February 13, 2002 at 06:54:27:
you need to have the sw grounded thru the steering post and make sure the resistor on the sw is gooe is the rest of the wires good if the gen is charging then the sw on hi should work if the rest of the system is good are the brushes set right 3.2 bars between the brushes or more the third brush is adjustable for this to charge at a higher rate when the sw is on hi-charge
Post A Followup
: Re: Re: Generator-Bob M Help ?
Today's Featured Article - Tuning-Up Your Tractor: Plugs & Compression Testing - by Curtis Von Fange. The engine seems to run rough. In the exhaust you can hear an occasion 'poofing' sound like somethings not firing on all cylinders. Under loaded conditions the tractor seems to lack power and it belches black smoke out of the exhaust. For some reason it just doesn't want to start up without cranking and cranking the starter. All these conditions can be signals that your unit is in need of a tune up. Ok, so what is involved in a tune up? You say, swap plugs and file the points....now tha ... [Read Article]
