Re: Re: Re: Overheated 1466
Posted by MAGNUM on February 14, 2002 at 06:43:20 from (209.143.22.75):
In Reply to: Re: Re: Overheated 1466 posted by John on February 11, 2002 at 09:53:32:
to replace the o-rings the sleeves have to come out the top of the block (right?) so i would replace the o-rings on the sleeves that you see are leaking and put a new style head gasket on while your there.
jeff
Post A Followup
: Re: Re: Re: Re: Overheated 1466
