Re: Tractor Vet
Posted by the tractor vet on February 14, 2002 at 19:44:58 from (216.196.13.153):
In Reply to: Tractor Vet posted by Jim on February 14, 2002 at 13:07:17:
The spring kits that i use i normaly don't have to change it it usualy comes in around 250 to 265 psi but if you must lower the prussure then you grind off one coil on the inner spring of the prussure reg. for every ten pounds you need to drop but if you need more then you must strech the inner spring .
Post A Followup
: Re: Re: Tractor Vet
