Re: Flywheel Ring Gear Removal A, B or BN
Posted by RPM on February 15, 2002 at 07:07:25 from (63.110.182.225):
In Reply to: Flywheel Ring Gear Removal A, B or BN posted by RAY a on February 14, 2002 at 18:17:29:
You can most likely drive it off carefully with no heat, just keep tapping it by rotating, getting it back on takes heat, either by acetylene or LP or maybe oven, never tried that, ranges are pretty scarce in most shops, when you get it hot enough it will drop on, but be quick about it.
Post A Followup
: Re: Re: Flywheel Ring Gear Removal A, B or BN
