Re: Estimated Value
Posted by Phil Auten (Tx) on February 15, 2002 at 13:20:27 from (63.173.243.102):
In Reply to: Estimated Value posted by Mark O. on February 15, 2002 at 13:09:30:
Mark,
The value will depend on location more than anything else. The closer you get to a large city, the more the tractor will bring. Where I am near Waco, Tx. that would probably be a $800-$1,000 tractor. The problems you mentioned won't be hard or expensive to fix (except, possibly, the radiator). Most likely the lights are still 6V and the tractor has a 12V battery in it since you said it has an alternator instead of a generator. However, if the tractor is a '41 or '46 model, it should be a plain A and not a Super A. The Super A's did not appear until '47. Does it have a Lift-all hydraulic unit on it? If it does, add $200-$500 to the value. That would also most likely make it a Super A. Check the serial number tag (under the seat on the bracket closest to the gearshift) and check the serial number in the Research & Info section of this site to determine exactly what year the tractor is.
Phil
Post A Followup
: Re: Re: Estimated Value
Today's Featured Article - Farmall 460: That's My Girl - by LeAnn R. Ralph. How many sounds can you think of that are as familiar to you as your own breathing? What about the hum of your refrigerator? Or the thump of your clothes dryer? Maybe the engine of your car? You hear those sounds every day, and you don't think much about them, do you. I can think of a few common, ordinary sounds in my daily life, too. ... [Read Article]
