Re: Re: Re: Re: Estimated Value
Posted by Hugh MacKay on February 15, 2002 at 16:49:20 from (142.177.105.119):
In Reply to: Re: Re: Re: Estimated Value posted by John in Maryland on February 15, 2002 at 16:30:19:
I didn't intend to be abrupt John, as I reread my post that is the way it sounded to me,my apology. The alternator I used was the same alternator as on my 85 Chevy pickup. I went to a local auto electric shop with my burned out 6 volt generator and had a new 6 volt battery in tractor. I was in a hurry as I was doing row crop work in vegetables. At time I wanted to keep tractor all orginal including gen. However after using tractor with alternator, I will never change back. I notice the antique purests will use modern paints, etc., why not electricity.
Post A Followup
: Re: Re: Re: Re: Re: Estimated Value
Today's Featured Article - Tuning-Up Your Tractor: Plugs & Compression Testing - by Curtis Von Fange. The engine seems to run rough. In the exhaust you can hear an occasion 'poofing' sound like somethings not firing on all cylinders. Under loaded conditions the tractor seems to lack power and it belches black smoke out of the exhaust. For some reason it just doesn't want to start up without cranking and cranking the starter. All these conditions can be signals that your unit is in need of a tune up. Ok, so what is involved in a tune up? You say, swap plugs and file the points....now tha ... [Read Article]
