Farmall Tractors Discussion Board
Re: 560 factory turbo
Posted by Kev in iowa on July 29, 1999 at 16:31:30 from (207.177.4.133):
In Reply to: 560 factory turbo posted by chris brown on July 29, 1999 at 16:16:05:
I know the turbo is wrong unless he means M&W Gear factory. 560 only came with 2 point hitches and while they can be adapted most don't transfer down force the way the fergeson system can. The wide front could be factory but after the other two I would expect a Swartz axel. Find an expert or learn all you can and go buy it for a song, maybe. I wouldn't buy a diesel unless I could see it runn on a pto dynometer for ten min at least, this is a real work out so running hot proablems will crop up. Also drive it in every gear with the throttel way back and listen for klunks in the trany. Look for a triangle on the id plate to see is the rearend has been beefed up. this was covered two weeks ago right here.
Post a Followup
: Re: Re: 560 factory turbo
