Re: IH 1086 shifting
Posted by phil on February 16, 2002 at 12:25:06 from (209.240.222.132):
In Reply to: IH 1086 shifting posted by BrianS on February 16, 2002 at 07:12:33:
I'd have to agree with Steve@nd. I have both a 1086 and 2090 and would definitely choose the Case with powershift. you have more speed selection in any one gear and quicker reverse on the Case where as in the 1086 you only have torque ahead or back in any one gear. In the Case you definitely have to manually downshift the powershift to 1st range instead of using the clutch to bring it back to 1st cuz it will give you one heck of a jolt, unless the linkages are set right. i have a 1070 that will throw you into the cab window if you try that but then our 2090 is as smooth as can be downshifting with the clutch.
Post A Followup
: Re: Re: IH 1086 shifting
