Farmall M side cover oil leak
Posted by Marlin Mangels on February 17, 2002 at 04:07:07 from (205.229.202.2):
My '51 M has an oil leak around the side cover bolt that is just ahead of the crankcase vent. Can I cure this by putting some sort of seal under the bolt head, or do I need to remove the side cover and replace the cork gasget? If I have to remove the side cover, do I need to remove the distributor and coil to get it out? Thanks.
Post A Followup
: Re: Farmall M side cover oil leak
