Re: Re: Re: Re: M Farmall grader
Posted by JDM on February 17, 2002 at 04:55:16 from (206.74.34.91):
In Reply to: Re: Re: Re: M Farmall grader posted by Lenn on February 16, 2002 at 18:40:45:
Well,from what I know of those type of wheels,which is limited.The only thing that holds them on is that big bolt.My brothers I -4 has the same setup.In fact one wheel we are going to have trouble pulling off.but thats not your problem.Maybe you should try a little Loc-Tite on that bolt.Use a mild flavor to keep it from coming out but still allow you to take the bolt out.Also use a lockwasher between the bolt head and the flat washer.Going with the M axles and housing will make the rear of this thing wider as the housings are longer than what you have on there.
Post A Followup
: Re: Re: Re: Re: Re: M Farmall grader
