Re: M Farmall grader
Posted by Old-Dutch on February 17, 2002 at 06:32:55 from (216.165.154.133):
In Reply to: M Farmall grader posted by Lenn on February 16, 2002 at 16:29:55:
Lenn, my option would be to drill three holes in at an angle from outside triangle fashion. Making sure that as you come to axle it will be coming into valley of axle spline from three opposite points, to center wheel on axle. Use grade eight 9/16" or 5/8" bolts. Taper the nose of bolt to fit spline as it pulls in, with tractor jacked up turn wheel so it is tracking fair draw in evenly and tight. With edge of hole flat make sure you have a locknut to hold it once tightened. This will keep the wheel from walking around axle. Another thing to make sure of is that the wheel is drawing in tight to the bearing when you tighten your bolt and washer, if not shim it because that also can be a factor in keeping it tight. If it is all tight when done that should hold it. Done this in past and worked for me. Just an idea for you. Good luck.
Home
| Forums
Today's Featured Article -
Oil Bath Air Filters - by Chris Pratt. Some of us grew up thinking that an air filter was a paper thing that allowed air to pass while trapping dirt particles of a particles of a certain size. What a surprise to open up your first old tractor's air filter case and find a can that appears to be filled with the scrap metal swept from around a machine shop metal lathe. To top that off, you have a cup with oil in it ("why would you want to lubricate your carburetor?"). On closer examination (and some reading in a AC D-14 service manual), I found out that this is a pretty ingenious method of cleaning the air in the tractor's intake tract.
... [Read Article]
Latest Ad:
[More Ads]
Copyright © 1997-2025 Yesterday's Tractor Co. All Rights Reserved. Reproduction of any part of this website, including design and content, without written permission is strictly prohibited. Trade Marks and Trade Names contained and used in this Website are those of others, and are used in this Website in a descriptive sense to refer to the products of others. Use of this Web site constitutes acceptance of our User Agreement and Privacy Policy TRADEMARK DISCLAIMER: Tradenames and Trademarks referred to within Yesterday's Tractor Co. products and within the Yesterday's Tractor Co. websites are the property of their respective trademark holders. None of these trademark holders are affiliated with Yesterday's Tractor Co., our products, or our website nor are we sponsored by them. John Deere and its logos are the registered trademarks of the John Deere Corporation. Agco, Agco Allis, White, Massey Ferguson and their logos are the registered trademarks of AGCO Corporation. Case, Case-IH, Farmall, International Harvester, New Holland and their logos are registered trademarks of CNH Global N.V. Yesterday's Tractors - Antique Tractor HeadquartersWebsite Accessibility Policy |
