Re: Difference between a IH wide-front and Swartz?
Posted by Matthew on February 17, 2002 at 11:44:31 from (64.68.163.44):
In Reply to: Difference between a IH wide-front and Swartz? posted by John in Maryland on February 17, 2002 at 10:52:24:
The Swartz's wishbone is welded to the axle tube. Where the IH wishbone has nuts on the end of them and are run through tubes that are welded to the axle.
Post A Followup
: Re: Re: Difference between a IH wide-front and Swartz?
