Re: 1943 Farmall M Starter Switch Location
Posted by The Red on February 17, 2002 at 13:52:46 from (12.84.238.88):
In Reply to: 1943 Farmall M Starter Switch Location posted by O2W on February 17, 2002 at 12:42:13:
If your M has a flat panel where the belt pulley activation lever and the choke lever are, the coil switch goes in the bottom right hole on that panel. There were options on where you could locate your starter switch. Behind the steering wheel on the rear gas tank support, as you described it, is one of the correct options.
Post A Followup
: Re: Re: 1943 Farmall M Starter Switch Location
