Re: Farmall c overheating
Posted by Haas on February 17, 2002 at 17:15:12 from (129.37.117.118):
In Reply to: Farmall c overheating posted by jason r on February 17, 2002 at 14:45:22:
The crack should have nothing to do with overheating as long as you have sufficient water level in the cooling system. The way you describe the water temp with warm, not overly hot water at the top of the radiator sounds pretty normal. Maybe the engine dies because of the coil or some other problem. When you flushed it out, you should take off the radiator and the two necks bolted to the head and block. Then use a tube to reach back in as far as you can to flush it out. A pressure washer would be good. I would recommend having the crack in the block welded. This is a common problem and probably happened because someone let if freeze. I agree with Michael that incorrect timing might be causing the overheating. A friend had a Super C that was overheating like that, and I found the timing to be way off. So far off that I had a hard time finding the TDC mark on the flywheel. The tractor ran surprizingly good for as far off as the timing was. The symptoms were overheating and rapid fouling of the plugs.
Home
| Forums
Today's Featured Article -
Hydraulic Basics - Part 2 - by Curtis Von Fange. In the last entry to this series we gave a brief overview of hydraulic system theory, its basic components and how it works. Now lets take a look at some general maintenance tips that will keep our system operating to its fullest potential. The two biggest enemies to a hydraulic system are dirt and water. Dirt can score the insides of cylinders, spool valves and pumps. Wate
... [Read Article]
Latest Ad:
[More Ads]
Copyright © 1997-2025 Yesterday's Tractor Co. All Rights Reserved. Reproduction of any part of this website, including design and content, without written permission is strictly prohibited. Trade Marks and Trade Names contained and used in this Website are those of others, and are used in this Website in a descriptive sense to refer to the products of others. Use of this Web site constitutes acceptance of our User Agreement and Privacy Policy TRADEMARK DISCLAIMER: Tradenames and Trademarks referred to within Yesterday's Tractor Co. products and within the Yesterday's Tractor Co. websites are the property of their respective trademark holders. None of these trademark holders are affiliated with Yesterday's Tractor Co., our products, or our website nor are we sponsored by them. John Deere and its logos are the registered trademarks of the John Deere Corporation. Agco, Agco Allis, White, Massey Ferguson and their logos are the registered trademarks of AGCO Corporation. Case, Case-IH, Farmall, International Harvester, New Holland and their logos are registered trademarks of CNH Global N.V. Yesterday's Tractors - Antique Tractor HeadquartersWebsite Accessibility Policy |
