Re: 300 UTILITY T/A REBUILD
Posted by Jim on February 17, 2002 at 18:21:08 from (12.87.72.32):
In Reply to: 300 UTILITY T/A REBUILD posted by MARK on February 17, 2002 at 15:29:41:
It might be less money, if you just replaced the bad parts, carrier, ramp and rollers along with the gaskets and seals, I believe you still can do this. I'll check parts in morning and let you know. Jim
Post A Followup
: Re: Re: 300 UTILITY T/A REBUILD
