Re: headlights not working
Posted by JD Humm on February 18, 2002 at 02:18:57 from (67.202.17.155):
In Reply to: headlights not working posted by goph on February 17, 2002 at 14:58:48:
All the posts are good advice. I have seen the old original wires broken inside the light bar tube as well as grounding problems that were mentioned, if you have a multimeter check for DC voltage at the wire with you meter, place one meter lead on the wire and the other to a good ground. Meter should read the battery voltage if the wire is good.
Post A Followup
: Re: Re: headlights not working
