What makes a TA slip?
Posted by Jim on February 18, 2002 at 14:10:22 from (63.62.234.5):
The TA on my 300 RC works fine as far as shifting in and out, pulling, and running smooth. Occasionally under heavy load it will slip and the tractor will slow down or stop unless I shift it out of TA and go to a straight gear. But sometimes it "will" pull a heavy load and not slip! Is this just a matter of adjustment or is there some type of internal clutch disk that is slipping?
Post A Followup
: Re: What makes a TA slip?
