Re: A lighting
Posted by Farmer Bob on February 18, 2002 at 19:49:29 from (66.152.73.102):
In Reply to: A lighting posted by Jo on February 18, 2002 at 14:13:56:
Jo, you left out some things we need to know...like is the generator a 12V or still 6V? Has the tractor been coverted to 12V with alternator? If 12V were the original bulbs changed to 12V? Have you checked the lighting wiring for breaks/corrosion etc?
If the Generator is still 6V, make sure it has 6V bulbs, good wiring, with everything cleaned up and the lights have good grounds where they connect to the tractor. Putting in a new 6V battery should do the trick. Just make sure your regulator/cutout is working properly to keep your new battery recharged.//FB
Post A Followup
: Re: Re: A lighting
Today's Featured Article - The Fordson F Ignition System - by Anthony West. A fellow restorer contacted me earlier this year asking for some help and advice on a model F that he was restoring. He had over a period of months spent a fair amount of his hard earned cash on replacement parts for the old "trembler" ignition. Sadly though all his efforts seemed to be a waste of time and money as he still couldn''t get the temperamental old thing to run correctly!! If i said that this was a little frustrating for him that would be "conservative" in fact the problem had reduce ... [Read Article]
