Re: Adding 560 hydraulic fluid
Posted by Keith B on February 18, 2002 at 20:12:25 from (216.151.70.38):
In Reply to: Adding 560 hydraulic fluid posted by Bob on February 18, 2002 at 19:32:50:
There is a triangle shape cap(plate) on the top of the deck with three bolts in it. (Similar to what the gear shift goes in, and to the right of it) That is where the hydraulic/transmission fluid is added. First remove the plug on the left side of the transmission case. This is the full/level plug. Add fluid until you see it coming out the full/level plug. Use Hy-Tran fluid by Case-IH or something comparable from TSC.
Post A Followup
: Re: Re: Adding 560 hydraulic fluid
