Re: Brush Hog Type?
Posted by John in Maryland on February 19, 2002 at 11:54:07 from (66.56.220.94):
In Reply to: Brush Hog Type? posted by scotty on February 19, 2002 at 11:30:14:
You are gonna have a problem with that offset pto. If you had fast hitch, it wouldn't be a problem because the bush hog would always be straight behind the tractor. I guess you could use a pull type, but would only be able to turn one way, carefully. King kutter makes an okay small pull type bushhog. www.kingkutter.com Maybe someone will know better than I, I have a 140 and have a 5' finishing mower on it, but it's a fast hitch.
Post A Followup
: Re: Re: Brush Hog Type?
