Re: Difference between a IH wide-front and Swartz?
Posted by sod on February 19, 2002 at 14:26:25 from (209.206.151.34):
In Reply to: Difference between a IH wide-front and Swartz? posted by John in Maryland on February 17, 2002 at 10:52:24:
I have a Schwartz front end on my 450 and it is pretty stout. The tie rods are behind the axle/cross member. The vertical piece that holds the spindles have splines on them, not just one keyway.
It comes down to what you want.
sod
Post A Followup
: Re: Re: Difference between a IH wide-front and Swartz?
