Re: Re: farmall c overheating part 2
Posted by ScottyNY on February 20, 2002 at 12:33:02 from (128.59.123.240):
In Reply to: Re: farmall c overheating part 2 posted by John in Maryland on February 20, 2002 at 10:42:34:
We're over-engineering a little here. A thermosiphon is as simple as it gets. Hot water will rise above cooler water. cool water will settle out below hot water. If you can get this to happen in a loop , you will get a flow. Water heats up as it takes heat from around the sleeves, and rises into the head. It picks up more heat from the head, rising further, out the top hose into the top of the radiator. With the water in the radiator cooling, and new hot water coming in the top, the natural flow in the radiator is downward and into the hose that carries it back to the hot side where it will rise. Get a vertical loop, put all of the heat generating stuff on one side, the heat dissipating stuff on the other, make sure that the water at the top is deep/sufficient enough to carry the flow, and it will flow. Et voila! a thermosiphon! A vacuum at the top would only serve to lower the boiling point of the fluid--counterproductive. Pressure-retaining cap at the top would , and frequently does, raise the boiling point- some utility to be had there but not always necessary. Potential problems will result from things such as insufficient flow which might be traced to things like a restriction on either the warm or cool side or, again, an insufficient amount of water in the overall system which restricts the flow at the top. From of what I've been following on this particular case, It's sounding like a restriction and, with the hot side having been flushed well, it's looking more and more like the radiator. Just for testing, fill the system slightly fuller than you would want it to be normally, up into the neck of the radiator a little. Start cold and carefully note the water lever in the radiator. It stays cold but heats up suddenly. Did the level rise? Water/antifreeze solutions expand as they heat up but not that radically. If you notice the level rising and/or falling, It's a good chance something is boiling somehere there, expanding rapidly into bubbles and the bubble is forcing the hot stuff through suddenly. A thorough flushing or mechanical cleaning then of the radiator would be indicated. But don't rule out teh possibility of a (retro) rocket scientist having retro-fitted some manner of thermostat that could be in there blocking things.
Home
| Forums
Today's Featured Article -
Women and Tractors - Tractor Engine Repair - by Teri Burkholder. One of the great things about working on a tractor engine with your other half is that you know what he is thinking of at all times and can anticipate his every move and his next thought of what he will do. With Ben, anyway, I can tell! He'll be busy working and I’m handing him tools and he says, "give me that..." and I’ve already got it in his hand or "hand me that....."and I’ve got the portable light right where he needed it placed to see. "Run in the house and get me a...."as I open th
... [Read Article]
Latest Ad:
[More Ads]
Copyright © 1997-2025 Yesterday's Tractor Co. All Rights Reserved. Reproduction of any part of this website, including design and content, without written permission is strictly prohibited. Trade Marks and Trade Names contained and used in this Website are those of others, and are used in this Website in a descriptive sense to refer to the products of others. Use of this Web site constitutes acceptance of our User Agreement and Privacy Policy TRADEMARK DISCLAIMER: Tradenames and Trademarks referred to within Yesterday's Tractor Co. products and within the Yesterday's Tractor Co. websites are the property of their respective trademark holders. None of these trademark holders are affiliated with Yesterday's Tractor Co., our products, or our website nor are we sponsored by them. John Deere and its logos are the registered trademarks of the John Deere Corporation. Agco, Agco Allis, White, Massey Ferguson and their logos are the registered trademarks of AGCO Corporation. Case, Case-IH, Farmall, International Harvester, New Holland and their logos are registered trademarks of CNH Global N.V. Yesterday's Tractors - Antique Tractor HeadquartersWebsite Accessibility Policy |
