Re: Re: Setting stop clips on Super A Touch Control
Posted by ScottyNY on February 20, 2002 at 12:41:35 from (128.59.123.240):
In Reply to: Re: Setting stop clips on Super A Touch Control posted by Paul Shuler on February 20, 2002 at 09:13:38:
Paul, I believe you are thinking of the stop clips up on the control levers, the ones you set with the thumbscrews. Those are the ones intended for the purpose you describe. I think Al is talking about those that are just under the "hood" of the TC unit and are held in place by two(each) of the set screws that pass though to the outside. They limit the full range of the piston throw, so you dont blow out your syste. Al, I asked a dealer about that gauge once, and was told not to bother, to do it by ear. The gauge would simply tell you when the system was under high pressure, and you can generally hear that as well. It worked for me. If I ever had a chance to find and use an appropriate gauge, I guess I would, but my TC works just fine.
Post A Followup
: Re: Re: Re: Setting stop clips on Super A Touch Control
