Re: farmall c overheating part 2
Posted by Larry W. on February 21, 2002 at 05:43:09 from (216.228.43.81):
In Reply to: farmall c overheating part 2 posted by jason r on February 20, 2002 at 06:49:55:
There is a possibility here that you have a blown head gsket. Did you check the temperature with a thermoneter, or just assume it was boiling because of the bubbles? When the engine gets warm, a leaky gasket, or cracked head might manifest with bubbling in the radiator. A blown head gasket would also allow the water to heat rapidly.
Post A Followup
: Re: Re: farmall c overheating part 2
