Re: gene b will you answer me??
Posted by ScottyNY on February 21, 2002 at 08:25:24 from (128.59.123.240):
In Reply to: gene b will you answer me?? posted by One Row on February 21, 2002 at 07:30:12:
OR -- I had the high-tem aluminum recommended to me when I rebuilt my 51 SuperC. Worked like a charm. I did a couple of light coats on each side, keeping it tacky, and set it on tacky. Held fine through the first warmup. I let mine cool back down before retorquing and found quite a bit of slack on several of the studs.
Post A Followup
: Re: Re: gene b will you answer me??
